Ana içeriğe geç
HP Envy m6-n010dx Fan Replacement
Neye ihtiyacın var
  1. HP Envy m6-n010dx Fan Replacement, Battery: adım 1, 3 resimden 1. HP Envy m6-n010dx Fan Replacement, Battery: adım 1, 3 resimden 2. HP Envy m6-n010dx Fan Replacement, Battery: adım 1, 3 resimden 3.
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx Fan Replacement, Hard Drive: adım 2, 1 resimden 1.
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx Fan Replacement: adım 3, 2 resimden 1. HP Envy m6-n010dx Fan Replacement: adım 3, 2 resimden 2.
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx Fan Replacement: adım 4, 3 resimden 1. HP Envy m6-n010dx Fan Replacement: adım 4, 3 resimden 2. HP Envy m6-n010dx Fan Replacement: adım 4, 3 resimden 3.
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
  5. HP Envy m6-n010dx Fan Replacement, Fan: adım 5, 3 resimden 1. HP Envy m6-n010dx Fan Replacement, Fan: adım 5, 3 resimden 2. HP Envy m6-n010dx Fan Replacement, Fan: adım 5, 3 resimden 3.
    • Remove the screws highlighted in red
    • Pry off with prying tool the lower two grip pads highlighted in orange
    • You may need to use more force than feels necessary
    • Remove the two additional screws underneath the lower grip pads
    • Remove the large back panel to reveal the inner workings
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  6. HP Envy m6-n010dx Fan Replacement: adım 6, 3 resimden 1. HP Envy m6-n010dx Fan Replacement: adım 6, 3 resimden 2. HP Envy m6-n010dx Fan Replacement: adım 6, 3 resimden 3.
    • Locate fan
    • Gently remove tape that hold the heatsink and fan together
    • When reassembling , make sure to use new electrical tape so it will stick.
  7. HP Envy m6-n010dx Fan Replacement: adım 7, 3 resimden 1. HP Envy m6-n010dx Fan Replacement: adım 7, 3 resimden 2. HP Envy m6-n010dx Fan Replacement: adım 7, 3 resimden 3.
    • Loosen the four screws on the heat sink indicated in picture
    • Remove the heatsink
  8. HP Envy m6-n010dx Fan Replacement: adım 8, 2 resimden 1. HP Envy m6-n010dx Fan Replacement: adım 8, 2 resimden 2.
    • Gently disconnect the wire connecting the fan to the motherboard
  9. HP Envy m6-n010dx Fan Replacement: adım 9, 3 resimden 1. HP Envy m6-n010dx Fan Replacement: adım 9, 3 resimden 2. HP Envy m6-n010dx Fan Replacement: adım 9, 3 resimden 3.
    • Remove screws indicated in photo.
    • Remove fan
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,050
