Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide demonstrates how to properly remove the Hard Drive of a HP Envy m6-n010dx.
Parçalar
Hiçbir parça belirtilmedi.
  1. Find the battery removal slider. Slide it across while simultaneously popping out and removing the device's battery. Slide it across while simultaneously popping out and removing the device's battery.
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. Remove the five marked screws found under the battery using a philips head screwdriver.
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. Remove the small panel on the back by prying it off. This should reveal the hard drive. Remove the small panel on the back by prying it off. This should reveal the hard drive.
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  5. The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red. Gently pry off the cover to release the cable. Slowly lift the hard drive out and away from the device.
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 560
