Ana içeriğe geç
Fix Your Stuff
Right to Repair
Parts & Tools
Giriş
This guide demonstrates how to properly remove the Speaker of a HP Envy m6-n010dx.
  1. Find the battery removal slider. Slide it across while simultaneously popping out and removing the device's battery. Slide it across while simultaneously popping out and removing the device's battery.
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. Remove the five marked screws found under the battery using a philips head screwdriver.
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. Remove the small panel on the back by prying it off. This should reveal the hard drive. Remove the small panel on the back by prying it off. This should reveal the hard drive.
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red. Gently pry off the cover to release the cable. Slowly lift the hard drive out and away from the device.
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
  5. Remove the marked screws. Pry off the lower two grip pads. You may need to use more force than feels necessary.
    • Remove the marked screws.
    • Pry off the lower two grip pads.
    • You may need to use more force than feels necessary.
    • Remove the two additional screws underneath the lower grip pads.
    • Remove the large back panel to reveal the inner workings.
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  6. Locate the speaker. Locate the tape on the speaker. Peel back the tape, disconnecting it from the speaker.
    • Locate the speaker.
    • Locate the tape on the speaker.
    • Peel back the tape, disconnecting it from the speaker.
    • When reassembling the speaker, make sure to use new electrical tape so it will stick.
  7. Locate the connecting wire attached to the speaker. Disconnect the wire. Disconnect the wire.
    • Locate the connecting wire attached to the speaker.
    • Disconnect the wire.
  8. Use a screwdriver to unscrew the three screws on the speaker. Use a screwdriver to unscrew the three screws on the speaker.
    • Use a screwdriver to unscrew the three screws on the speaker.
  9. Remove the speaker. Remove the speaker. Remove the speaker.
    • Remove the speaker.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 117
