Ana içeriğe geç
HP Envy m6-p114dx Battery Replacement
Neye ihtiyacın var
  1. HP Envy m6-p114dx Battery Replacement, Back Panel: adım 1, 3 resimden 1. HP Envy m6-p114dx Battery Replacement, Back Panel: adım 1, 3 resimden 2. HP Envy m6-p114dx Battery Replacement, Back Panel: adım 1, 3 resimden 3.
    • Power the device off, unplug it, and ground yourself.
  2. HP Envy m6-p114dx Battery Replacement: adım 2, 1 resimden 1.
    • Remove the twelve screws in the back case using a Phillips #1 screwdriver.
  3. HP Envy m6-p114dx Battery Replacement: adım 3, 1 resimden 1.
    • Carefully wedge an iFixit opening tool under the cover and slide it alongside the case to ensure that all clips are un-clipped.
  4. HP Envy m6-p114dx Battery Replacement, Battery: adım 4, 2 resimden 1. HP Envy m6-p114dx Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the cable connecting the hard drive to the motherboard by carefully lifting the black tab, then pulling out the disconnected ribbon cable.
  5. HP Envy m6-p114dx Battery Replacement: adım 5, 2 resimden 1. HP Envy m6-p114dx Battery Replacement: adım 5, 2 resimden 2.
    • Remove the cable connecting the battery to the motherboard by gripping the fabric and pulling downward.
    • The cable is connected next to the RAM cards.
  6. HP Envy m6-p114dx Battery Replacement: adım 6, 2 resimden 1. HP Envy m6-p114dx Battery Replacement: adım 6, 2 resimden 2.
    • Remove the six screws that hold the battery down with a Phillips #0 screwdriver.
    • Once the screws are removed you should be able to easily lift up on the battery to remove it. (You may need to detach the ribbon cable glued to the battery )
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taylor Cheney
527 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team S1-G1, Saknee Fall 2019 Gateway, Team S1-G1, Saknee Fall 2019 üyesi
GCC-SAKNEE-F19S1G1
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 996
