Ana içeriğe geç
HP Envy m6-p114dx Ram Replacement
Neye ihtiyacın var
  1. HP Envy m6-p114dx Ram Replacement, Back Panel: adım 1, 3 resimden 1. HP Envy m6-p114dx Ram Replacement, Back Panel: adım 1, 3 resimden 2. HP Envy m6-p114dx Ram Replacement, Back Panel: adım 1, 3 resimden 3.
    • Power the device off, unplug it, and ground yourself.
  2. HP Envy m6-p114dx Ram Replacement: adım 2, 1 resimden 1.
    • Remove the twelve screws in the back case using a Phillips #1 screwdriver.
  3. HP Envy m6-p114dx Ram Replacement: adım 3, 1 resimden 1.
    • Carefully wedge an iFixit opening tool under the cover and slide it alongside the case to ensure that all clips are un-clipped.
  4. HP Envy m6-p114dx Ram Replacement, Ram: adım 4, 3 resimden 1. HP Envy m6-p114dx Ram Replacement, Ram: adım 4, 3 resimden 2. HP Envy m6-p114dx Ram Replacement, Ram: adım 4, 3 resimden 3.
    • There will be two metal tabs on the side of the stick, carefully push down the stick then push the clips to the side to detach it from the slot
    • Remove the RAM by pulling it directly out of the port.
  5. HP Envy m6-p114dx Ram Replacement: adım 5, 1 resimden 1.
    • Insert RAM stick all the way into the slot, lining up the groove in the stick.
    • Press firmly down until the tabs click into place
Sonuç
Taylor Cheney
527 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team S1-G1, Saknee Fall 2019 Gateway, Team S1-G1, Saknee Fall 2019 üyesi
GCC-SAKNEE-F19S1G1
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 188
