Ana içeriğe geç
HP Envy x2 13-j002dx Battery Replacement
Neye ihtiyacın var
  1. HP Envy x2 13-j002dx Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
  2. HP Envy x2 13-j002dx Battery Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two 3.5 mm screws from the bottom of the device—one on each side of the keyboard dock.
  3. HP Envy x2 13-j002dx Battery Replacement: adım 3, 1 resimden 1.
    • Use a pair of tweezers to remove the screw covers on the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws.
  4. HP Envy x2 13-j002dx Battery Replacement: adım 4, 2 resimden 1. HP Envy x2 13-j002dx Battery Replacement: adım 4, 2 resimden 2.
    • Use an opening pick to remove the plastic cover above the back stand.
    • Pry the cover off.
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws.
  5. HP Envy x2 13-j002dx Battery Replacement: adım 5, 1 resimden 1.
    • Use an opening pick and a prying tool, and go around the device to remove the back cover from the rest of the assembly.
  6. HP Envy x2 13-j002dx Battery Replacement: adım 6, 1 resimden 1.
    • Unplug the battery from the motherboard.
  7. HP Envy x2 13-j002dx Battery Replacement: adım 7, 2 resimden 1. HP Envy x2 13-j002dx Battery Replacement: adım 7, 2 resimden 2.
    • Carefully pull up on the battery connector from the speaker.
    • Use a pair of tweezers and remove the taped down wire for the speaker.
    • Use a Phillips #00 screwdriver to remove the seven 3mm screws around the battery.
  8. HP Envy x2 13-j002dx Battery Replacement: adım 8, 1 resimden 1.
    • Carefully lift up and remove the battery.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
For step 2, when I was taking the screws out, they were held in by the magnets that were on either side of them making it difficult to remove. I ended up having to use another magnet to get them out.
Reed Jochimsen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 1,888
