Giriş
These instructions will guide you through the process to remove and replace the motherboard on the HP Envy x2 13-j002dx (Model #J9M64UA). In step 1 of this guide, you will remove the tablet’s outer shell to access the motherboard. The rest of guide shows you how to remove and replace the motherboard.
Neye ihtiyacın var
Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
Before removing the motherboard, clear away any dust, and ensure that the battery is already removed.
Bir başkası bu kılavuzu tamamladı.
