Ana içeriğe geç
HP Envy x2 13-j002dx Motherboard Replacement
Neye ihtiyacın var
  1. HP Envy x2 13-j002dx Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
  2. HP Envy x2 13-j002dx Motherboard Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two 3.5 mm screws from the bottom of the device—one on each side of the keyboard dock.
  3. HP Envy x2 13-j002dx Motherboard Replacement: adım 3, 1 resimden 1.
    • Use a pair of tweezers to remove the screw covers on the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws.
  4. HP Envy x2 13-j002dx Motherboard Replacement: adım 4, 2 resimden 1. HP Envy x2 13-j002dx Motherboard Replacement: adım 4, 2 resimden 2.
    • Use an opening pick to remove the plastic cover above the back stand.
    • Pry the cover off.
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws.
  5. HP Envy x2 13-j002dx Motherboard Replacement: adım 5, 1 resimden 1.
    • Use an opening pick and a prying tool, and go around the device to remove the back cover from the rest of the assembly.
  6. HP Envy x2 13-j002dx Motherboard Replacement: adım 6, 1 resimden 1.
    • Unplug the battery from the motherboard.
  7. HP Envy x2 13-j002dx Motherboard Replacement: adım 7, 2 resimden 1. HP Envy x2 13-j002dx Motherboard Replacement: adım 7, 2 resimden 2.
    • Carefully pull up on the battery connector from the speaker.
    • Use a pair of tweezers and remove the taped down wire for the speaker.
    • Use a Phillips #00 screwdriver to remove the seven 3mm screws around the battery.
  8. HP Envy x2 13-j002dx Motherboard Replacement: adım 8, 1 resimden 1.
    • Carefully lift up and remove the battery.
  9. HP Envy x2 13-j002dx Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Before removing the motherboard, clear away any dust, and ensure that the battery is already removed.
  10. HP Envy x2 13-j002dx Motherboard Replacement: adım 10, 2 resimden 1. HP Envy x2 13-j002dx Motherboard Replacement: adım 10, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the three 3.8 mm screws along the edge of the motherboard.
  11. HP Envy x2 13-j002dx Motherboard Replacement: adım 11, 2 resimden 1. HP Envy x2 13-j002dx Motherboard Replacement: adım 11, 2 resimden 2.
    • Disconnect the cable connectors from the motherboard. This can be done with either tweezers or with your fingers.
  12. HP Envy x2 13-j002dx Motherboard Replacement: adım 12, 2 resimden 1. HP Envy x2 13-j002dx Motherboard Replacement: adım 12, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the 3.2mm screws within the copper rings in the circuit board.
    • Using the Phillips #0 screwdriver, remove the 2.5mm and 4.25mm black screws on the motherboard.
  13. HP Envy x2 13-j002dx Motherboard Replacement: adım 13, 1 resimden 1.
    • Once the screws and cables are disconnected and removed, remove the motherboard from the frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Colton Moon
241 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 554
