Ana içeriğe geç
HP Envy x360 13-y013cl Power Jack Replacement
Neye ihtiyacın var
  1. HP Envy x360 13-y013cl Power Jack Replacement, Power Jack: adım 1, 3 resimden 1. HP Envy x360 13-y013cl Power Jack Replacement, Power Jack: adım 1, 3 resimden 2. HP Envy x360 13-y013cl Power Jack Replacement, Power Jack: adım 1, 3 resimden 3.
    • Unscrew and remove the 7.8 mm screws with a T5 screwdriver.
    • Use a plastic opening tool to pry the bottom cover off the laptop.
  2. HP Envy x360 13-y013cl Power Jack Replacement: adım 2, 1 resimden 1.
    • Locate the copper-colored heat sync.
    • Use a JIS #0 screwdriver to remove the four 2.7 mm screws that secure the heatsink.
    • After removing the screws, lift the heatsink directly off the computer.
  3. HP Envy x360 13-y013cl Power Jack Replacement: adım 3, 2 resimden 1. HP Envy x360 13-y013cl Power Jack Replacement: adım 3, 2 resimden 2.
    • Locate the right hinge just above the fan.
    • Use a JIS #0 screwdriver to remove two 4 mm screws from the hinge display assembly hinge.
    • Use a JIS #0 screwdriver to remove the 4.2 mm screw from directly below the power jack.
  4. HP Envy x360 13-y013cl Power Jack Replacement: adım 4, 2 resimden 1. HP Envy x360 13-y013cl Power Jack Replacement: adım 4, 2 resimden 2.
    • Using the plastic black spudger, pry the hinge back as shown with the red arrow.
    • Continuing with the black plastic spudger, dislodge the power supply's metal frame from the computer.
  5. HP Envy x360 13-y013cl Power Jack Replacement: adım 5, 1 resimden 1.
    • Disconnect the EH-JST connector and remove the entire power supply from computer (metal frame, wire, and connector).
Sonuç
Petersee
382 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Harley Spring 2023 IUPUI, Team 3-2, Harley Spring 2023 üyesi
IUPUI-HARLEY-S23S3G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 24
Her zaman: 322
