Ana içeriğe geç
HP Envy x360 15-bp143cl Battery Replacement
Neye ihtiyacın var
  1. HP Envy x360 15-bp143cl Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Battery Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Battery Replacement: adım 3, 1 resimden 1.
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Battery Replacement: adım 4, 1 resimden 1.
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Battery Replacement: adım 5, 2 resimden 1. HP Envy x360 15-bp143cl Battery Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Battery Replacement: adım 6, 1 resimden 1.
    • Pull the battery from the connecting port and lift to remove it from the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Riley Muehler
305 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G3, Regan Fall 2019 Cal Poly, Team S12-G3, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G3
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Thank you for the pictures and advice!
I did not see any memory. Can you tell me if there are two slots for upgrading? I read that one stick of memory is soldered and the other is socketed.
Regards!
Joseph Stateson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 77
Her zaman: 3,094
