Ana içeriğe geç
HP Envy x360 15-bp143cl Touchpad Replacement
Neye ihtiyacın var
  1. HP Envy x360 15-bp143cl Touchpad Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Touchpad Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Touchpad Replacement: adım 3, 1 resimden 1.
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Touchpad Replacement: adım 4, 1 resimden 1.
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Touchpad Replacement: adım 5, 2 resimden 1. HP Envy x360 15-bp143cl Touchpad Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Touchpad Replacement: adım 6, 1 resimden 1.
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: adım 7, 2 resimden 1. HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: adım 7, 2 resimden 2.
    • Use a spudger to peel the silver tape near the top right side of the touch pad.
  8. HP Envy x360 15-bp143cl Touchpad Replacement: adım 8, 2 resimden 1. HP Envy x360 15-bp143cl Touchpad Replacement: adım 8, 2 resimden 2.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 4mm screws securing the bottom metal bar.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the three 1mm screws securing the top of the touch pad.
  9. HP Envy x360 15-bp143cl Touchpad Replacement: adım 9, 1 resimden 1.
    • Remove the metal cover by lifting it away from the laptop.
  10. HP Envy x360 15-bp143cl Touchpad Replacement: adım 10, 2 resimden 1. HP Envy x360 15-bp143cl Touchpad Replacement: adım 10, 2 resimden 2.
    • Lift the bottom side of the touch pad.
    • Lift the black tab that secures the touch pad connecting cable to the laptop.
    • Pull the cable from the touch pad connecting port.
  11. HP Envy x360 15-bp143cl Touchpad Replacement: adım 11, 2 resimden 1. HP Envy x360 15-bp143cl Touchpad Replacement: adım 11, 2 resimden 2.
    • Lift the touch pad to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Spencer Berkins
574 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G3, Regan Fall 2019 Cal Poly, Team S12-G3, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G3
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Thanks now have to find one on E-bay….or?
Michael - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 1,465
