Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
The touch screen can be damage or wear out over time. This guide will show how to replace the touch screen of your device.
  1. Remove the two anti-tamper covers from the bottom corners of the screen using the spudger which will reveal two screws. Remove the two 3mm screws using the J00 Phillips screwdriver.
    • Remove the two anti-tamper covers from the bottom corners of the screen using the spudger which will reveal two screws.
    • Remove the two 3mm screws using the J00 Phillips screwdriver.
  2. Move the plastic opening tool along the seem while prying up to separate the display housing from the laptop cover.
    • Move the plastic opening tool along the seem while prying up to separate the display housing from the laptop cover.
    • If the touch screen housing is cracked, it may splinter or shatter while separating.
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. Remove the four 3mm screws using the Phillips #00 screwdriver.
    • Remove the four 3mm screws using the Phillips #00 screwdriver.
  5. Lift the white UPC tape using the spudger, and disconnect the the golden connector from the screen. There may be a piece of black tape connecting a bundle of wires to the screen. Remove the piece of black tape if present.
    • Lift the white UPC tape using the spudger, and disconnect the the golden connector from the screen.
    • There may be a piece of black tape connecting a bundle of wires to the screen. Remove the piece of black tape if present.
    • Remove the touch screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 46
Son 30 gün: 224
Her zaman: 6,555
