Ana içeriğe geç
HP Envy x360 15-u473cl Wi-Fi Card Replacement
Neye ihtiyacın var
  1. HP Envy x360 15-u473cl Wi-Fi Card Replacement, Battery: adım 1, 2 resimden 1. HP Envy x360 15-u473cl Wi-Fi Card Replacement, Battery: adım 1, 2 resimden 2.
    • Power off your laptop before beginning disassembly.
    • Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
    • Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
  2. HP Envy x360 15-u473cl Wi-Fi Card Replacement: adım 2, 1 resimden 1.
    • Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
  3. HP Envy x360 15-u473cl Wi-Fi Card Replacement: adım 3, 2 resimden 1. HP Envy x360 15-u473cl Wi-Fi Card Replacement: adım 3, 2 resimden 2.
    • Turn the device right side up and open the lid.
    • Insert the plastic opening tool in between the keyboard plate and the base of laptop.
    • Run the tool along seem, prying up as you go.
    • Separate the keyboard plate from the base, lifting from the front.
  4. HP Envy x360 15-u473cl Wi-Fi Card Replacement: adım 4, 1 resimden 1.
    • There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
    • Remove the keyboard plate from the device.
  5. HP Envy x360 15-u473cl Wi-Fi Card Replacement: adım 5, 1 resimden 1.
    • Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
  6. HP Envy x360 15-u473cl Wi-Fi Card Replacement: adım 6, 1 resimden 1.
    • Remove the three 4mm screws using the Phillips #0 screwdriver.
  7. HP Envy x360 15-u473cl Wi-Fi Card Replacement: adım 7, 1 resimden 1.
    • Disconnect the battery from the motherboard.
    • There may be tamper-proof tape holding the battery in place. Remove the tape if present.
    • Remove the battery from the device.
  8. HP Envy x360 15-u473cl Wi-Fi Card Replacement, Wi-Fi Card: adım 8, 1 resimden 1.
    • Remove one 3mm screw with the Phillips #00 screwdriver.
  9. HP Envy x360 15-u473cl Wi-Fi Card Replacement: adım 9, 1 resimden 1.
    • Disconnect the wireless card by pulling away from the black connector using the spudger.
    • Push up on the two wires to release the connectors and remove the Wi-Fi card from the device.
Sonuç
Matthew Ortman
163 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G3, Harley Fall 2019 IUPUI, Team S3-G3, Harley Fall 2019 üyesi
IUPUI-HARLEY-F19S3G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 719
