Ana içeriğe geç
HP Envy x360 15m-bp111dx Battery Replacement
Neye ihtiyacın var
  1. HP Envy x360 15m-bp111dx Battery Replacement, Back Panel: adım 1, 2 resimden 1. HP Envy x360 15m-bp111dx Battery Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Battery Replacement: adım 2, 3 resimden 1. HP Envy x360 15m-bp111dx Battery Replacement: adım 2, 3 resimden 2. HP Envy x360 15m-bp111dx Battery Replacement: adım 2, 3 resimden 3.
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Battery Replacement, Battery: adım 3, 2 resimden 1. HP Envy x360 15m-bp111dx Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Battery Replacement: adım 4, 3 resimden 1. HP Envy x360 15m-bp111dx Battery Replacement: adım 4, 3 resimden 2. HP Envy x360 15m-bp111dx Battery Replacement: adım 4, 3 resimden 3.
    • Carefully lift the battery, and pull it towards you to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tori Luongo
268 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-2, Hunter Spring 2022 Clemson, Team 2-2, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S2G2
5 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
This website has been very helpful but you only show how to remove a battery. You've left out the replace part of the replacement. Would really help. Thanks!
book mite - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 15
Son 30 gün: 35
Her zaman: 661
