Ana içeriğe geç
HP Envy x360 15m-bp111dx Touchpad Replacement
Neye ihtiyacın var
  1. HP Envy x360 15m-bp111dx Touchpad Replacement, Back Panel: adım 1, 2 resimden 1. HP Envy x360 15m-bp111dx Touchpad Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Touchpad Replacement: adım 2, 3 resimden 1. HP Envy x360 15m-bp111dx Touchpad Replacement: adım 2, 3 resimden 2. HP Envy x360 15m-bp111dx Touchpad Replacement: adım 2, 3 resimden 3.
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Touchpad Replacement, Battery: adım 3, 2 resimden 1. HP Envy x360 15m-bp111dx Touchpad Replacement, Battery: adım 3, 2 resimden 2.
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Touchpad Replacement: adım 4, 3 resimden 1. HP Envy x360 15m-bp111dx Touchpad Replacement: adım 4, 3 resimden 2. HP Envy x360 15m-bp111dx Touchpad Replacement: adım 4, 3 resimden 3.
    • Carefully lift the battery, and pull it towards you to remove it.
  5. HP Envy x360 15m-bp111dx Touchpad Replacement, Touchpad: adım 5, 3 resimden 1. HP Envy x360 15m-bp111dx Touchpad Replacement, Touchpad: adım 5, 3 resimden 2. HP Envy x360 15m-bp111dx Touchpad Replacement, Touchpad: adım 5, 3 resimden 3.
    • Use a Phillips screwdriver to remove the four 3.5 mm screws securing the bar on the touchpad.
    • Remove the bar from the touchpad.
  6. HP Envy x360 15m-bp111dx Touchpad Replacement: adım 6, 2 resimden 1. HP Envy x360 15m-bp111dx Touchpad Replacement: adım 6, 2 resimden 2.
    • Use a Phillips screwdriver to remove the three 2 mm screws securing the touchpad.
  7. HP Envy x360 15m-bp111dx Touchpad Replacement: adım 7, 3 resimden 1. HP Envy x360 15m-bp111dx Touchpad Replacement: adım 7, 3 resimden 2. HP Envy x360 15m-bp111dx Touchpad Replacement: adım 7, 3 resimden 3.
    • Flip the lock open on the ZIF connector using the opening tool to detach the ribbon from the motherboard.
    • Gently remove the touchpad from the motherboard.
  8. HP Envy x360 15m-bp111dx Touchpad Replacement: adım 8, 1 resimden 1.
    • The touchpad is now removed.
Sonuç
Haley Holmes
109 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 2-2, Hunter Spring 2022 Clemson, Team 2-2, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S2G2
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 228
