Ana içeriğe geç
HP Envy x360 15m-bq021dx Cooling Fan Replacement
Neye ihtiyacın var
  1. HP Envy x360 15m-bq021dx Cooling Fan Replacement, Battery: adım 1, 2 resimden 1. HP Envy x360 15m-bq021dx Cooling Fan Replacement, Battery: adım 1, 2 resimden 2.
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Cooling Fan Replacement: adım 2, 3 resimden 1. HP Envy x360 15m-bq021dx Cooling Fan Replacement: adım 2, 3 resimden 2. HP Envy x360 15m-bq021dx Cooling Fan Replacement: adım 2, 3 resimden 3.
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Cooling Fan Replacement: adım 3, 1 resimden 1.
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Cooling Fan Replacement: adım 4, 1 resimden 1.
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Cooling Fan Replacement: adım 5, 1 resimden 1.
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Cooling Fan Replacement, Cooling Fan: adım 6, 2 resimden 1. HP Envy x360 15m-bq021dx Cooling Fan Replacement, Cooling Fan: adım 6, 2 resimden 2.
    • Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
    • Be careful as the fan might be sharp in some places when removing it.
  7. HP Envy x360 15m-bq021dx Cooling Fan Replacement: adım 7, 2 resimden 1. HP Envy x360 15m-bq021dx Cooling Fan Replacement: adım 7, 2 resimden 2.
    • Remove the connector clip with the tweezers.
  8. HP Envy x360 15m-bq021dx Cooling Fan Replacement: adım 8, 1 resimden 1.
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  9. HP Envy x360 15m-bq021dx Cooling Fan Replacement: adım 9, 2 resimden 1. HP Envy x360 15m-bq021dx Cooling Fan Replacement: adım 9, 2 resimden 2.
    • Remove the cooling fan.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I'm considering attempting this repair. I am curious as to why the instructions direct me to remove the battery before removing the fan. From the pictures shown above, it does not appear that battery is mechanically blocking the removal of the fan. Is the purpose of this step to remove a phisical impedance, or is the reason to remove power from the he device?
Daniel Abrams - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 941
