Ana içeriğe geç
HP Envy x360 15m-bq021dx RAM Replacement
Neye ihtiyacın var
  1. HP Envy x360 15m-bq021dx RAM Replacement, Battery: adım 1, 2 resimden 1. HP Envy x360 15m-bq021dx RAM Replacement, Battery: adım 1, 2 resimden 2.
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx RAM Replacement: adım 2, 3 resimden 1. HP Envy x360 15m-bq021dx RAM Replacement: adım 2, 3 resimden 2. HP Envy x360 15m-bq021dx RAM Replacement: adım 2, 3 resimden 3.
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx RAM Replacement: adım 3, 1 resimden 1.
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx RAM Replacement: adım 4, 1 resimden 1.
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx RAM Replacement: adım 5, 1 resimden 1.
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx RAM Replacement, RAM: adım 6, 1 resimden 1.
    • Remove the tape near the RAM storage.
  7. HP Envy x360 15m-bq021dx RAM Replacement: adım 7, 2 resimden 1. HP Envy x360 15m-bq021dx RAM Replacement: adım 7, 2 resimden 2.
    • Use a small blue opening tool to pry open the protective metal cover.
  8. HP Envy x360 15m-bq021dx RAM Replacement: adım 8, 1 resimden 1.
    • Pull on the silver pins away from the RAM on both sides.
  9. HP Envy x360 15m-bq021dx RAM Replacement: adım 9, 2 resimden 1. HP Envy x360 15m-bq021dx RAM Replacement: adım 9, 2 resimden 2.
    • Pull the RAM up and out to remove.
Sonuç
Hunter Reihart
506 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 1,639
