Ana içeriğe geç
HP Envy x360 15m-bq021dx Wi-Fi Card Replacement
Neye ihtiyacın var
  1. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Battery: adım 1, 2 resimden 1. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Battery: adım 1, 2 resimden 2.
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 2, 3 resimden 1. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 2, 3 resimden 2. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 2, 3 resimden 3.
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 3, 1 resimden 1.
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 4, 1 resimden 1.
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 5, 1 resimden 1.
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Cooling Fan: adım 6, 2 resimden 1. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Cooling Fan: adım 6, 2 resimden 2.
    • Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
    • Be careful as the fan might be sharp in some places when removing it.
  7. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 7, 2 resimden 1. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the connector clip with the tweezers.
  8. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 8, 1 resimden 1.
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  9. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 9, 2 resimden 1. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 9, 2 resimden 2.
    • Remove the cooling fan.
  10. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Motherboard: adım 10, 3 resimden 1. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Motherboard: adım 10, 3 resimden 2. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Motherboard: adım 10, 3 resimden 3.
    • Using a Phillips #1, remove the seven M2.0x3.2 screws.
    • Undo the six connections using the blue opening tool.
  11. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 11, 3 resimden 1. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 11, 3 resimden 2. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 11, 3 resimden 3.
    • Carefully remove the aux port from the frame of the computer as shown.
  12. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 12, 2 resimden 1. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: adım 12, 2 resimden 2.
    • Pull the mother board up and away from frame of the computer.
  13. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Wi-Fi Card: adım 13, 3 resimden 1. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Wi-Fi Card: adım 13, 3 resimden 2. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Wi-Fi Card: adım 13, 3 resimden 3.
    • Flip the motherboard over.
    • Pull the Wi-Fi card out from the slot.
    • Remember the orientation the Wi-Fi card is in, as it must be inserted in the same way.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 7
Son 30 gün: 62
Her zaman: 774
