Ana içeriğe geç
HP Envy x360 15m-bq121dx Cooling Fan Replacement
Neye ihtiyacın var
  1. HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 1. HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 2.
    • Be sure the computer is powered off.
    • Remove the rubber strip along the top of the backside of the computer.
    • On the back panel of the device, remove the four (4) 2.5 mm screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq121dx Cooling Fan Replacement: adım 2, 3 resimden 1. HP Envy x360 15m-bq121dx Cooling Fan Replacement: adım 2, 3 resimden 2. HP Envy x360 15m-bq121dx Cooling Fan Replacement: adım 2, 3 resimden 3.
    • To remove the back cover, use the spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
    • Be sure to not damage any of the electronics on the inside.
  3. HP Envy x360 15m-bq121dx Cooling Fan Replacement: adım 3, 1 resimden 1.
    • Use the Philips #0 screwdriver to remove seven 2 mm screws from battery.
  4. HP Envy x360 15m-bq121dx Cooling Fan Replacement: adım 4, 1 resimden 1.
    • Lift and pull the front of the battery up and out away from the connector to remove.
  5. HP Envy x360 15m-bq121dx Cooling Fan Replacement: adım 5, 2 resimden 1. HP Envy x360 15m-bq121dx Cooling Fan Replacement: adım 5, 2 resimden 2.
    • Using a Philips #0 screwdriver, remove the three 2 mm screws located around the cooling fan as shown in this picture.
    • The fan may have sharp edges so be careful upon removal.
  6. HP Envy x360 15m-bq121dx Cooling Fan Replacement: adım 6, 2 resimden 1. HP Envy x360 15m-bq121dx Cooling Fan Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the connector clip with the tweezers.
  7. HP Envy x360 15m-bq121dx Cooling Fan Replacement: adım 7, 1 resimden 1.
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  8. HP Envy x360 15m-bq121dx Cooling Fan Replacement: adım 8, 2 resimden 1. HP Envy x360 15m-bq121dx Cooling Fan Replacement: adım 8, 2 resimden 2.
    • Remove the cooling fan.
Sonuç
Fabien Perez
157 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 38
Her zaman: 1,821
