Giriş
This guide will demonstrate how to replace the battery in the HP Envy x360 15m-cn0011dx laptop.
The battery is the component in the computer to power on the device. If you don't have a battery then you can not turn your computer on.
A swollen battery has less power life compared to a new one. If your battery is swollen then this guide is for you. It will show how to replace a swollen battery.
Make sure your device is fully powered off before attempting this guide.
Neye ihtiyacın var
Remove the six 3.3 mm screws from the battery pack using a Phillips #00 screwdriver.
Bir başkası bu kılavuzu tamamladı.
