Ana içeriğe geç
HP Envy x360 15m-cn0012dx Fan Replacement
Neye ihtiyacın var
  1. HP Envy x360 15m-cn0012dx  Fan Replacement, Fan: adım 1, 2 resimden 1. HP Envy x360 15m-cn0012dx  Fan Replacement, Fan: adım 1, 2 resimden 2.
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx  Fan Replacement: adım 2, 3 resimden 1. HP Envy x360 15m-cn0012dx  Fan Replacement: adım 2, 3 resimden 2. HP Envy x360 15m-cn0012dx  Fan Replacement: adım 2, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx  Fan Replacement: adım 3, 3 resimden 1. HP Envy x360 15m-cn0012dx  Fan Replacement: adım 3, 3 resimden 2. HP Envy x360 15m-cn0012dx  Fan Replacement: adım 3, 3 resimden 3.
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx  Fan Replacement: adım 4, 3 resimden 1. HP Envy x360 15m-cn0012dx  Fan Replacement: adım 4, 3 resimden 2. HP Envy x360 15m-cn0012dx  Fan Replacement: adım 4, 3 resimden 3.
    • Remove the two 4mm screws from the fan using a Phillips #0 screwdriver.
    • Peel the tape off of the multicolor cable bundle connecting the fan to the motherboard.
    • Use the iFixit opening tool to disconnect the connector.
  5. HP Envy x360 15m-cn0012dx  Fan Replacement: adım 5, 2 resimden 1. HP Envy x360 15m-cn0012dx  Fan Replacement: adım 5, 2 resimden 2.
    • Peel back the tape from the heatsink.
    • Use the Phillips #0 screwdriver to remove the four captive screws from the heatsink.
    • These screws will stay inside the heatsink while it is removed, simply loosen them until they disengage from the case and the heatsink becomes loose.
  6. HP Envy x360 15m-cn0012dx  Fan Replacement: adım 6, 2 resimden 1. HP Envy x360 15m-cn0012dx  Fan Replacement: adım 6, 2 resimden 2.
    • Unlatch the black cable from the plastic guides on the fan.
    • Lift the fan from the laptop case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ross Jeseritz
157 İtibar
1 Kılavuz yazıldı
Ekip
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 üyesi
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 53
Her zaman: 2,714
