Giriş
This guide will cover how to replace a cracked screen. While a faulty or glitching screen generally has to do with an issue in the hard drive or the software, if you have a cracked screen it would be advantageous to replace it following this guide.
Neye ihtiyacın var
Turn the laptop over and use the plastic opening tool to take off the rubber pads. You only need to take off the two pads at the top for this device.
Remove the six 4mm screws around the battery using a Phillips #0 screwdriver.
Make sure the the back panel is placed back on the computer so none of the internal components are exposed.
Open laptop and lay it completely flat.
Once the screen is detached from the back panel, direct your attention to the back of the screen where you will remove the tape holding the screen to the bottom panel.
Remove the grey tape covering the wires on both sides by slowly pulling back the tape as not to separate the tape from the adhesive.
Bir başkası bu kılavuzu tamamladı.
