Giriş
The hard drive stores all of the data for the laptop. Sometimes, you may hear your hard drive make a clicking noise. If you’re unable to load various files or if your computer is slow with loading files while the hard drive is clicking, you may need to replace the hard drive. This guide will show you how to properly replace this component.
Neye ihtiyacın var
Turn the laptop over and use the plastic opening tool to take off the rubber pads. You only need to take off the two pads at the top for this device.
Remove the six 4mm screws around the battery using a Phillips #0 screwdriver.
Disconnect the ribbon cable by flipping the black tab with the plastic opening tool.
Gently pull the ribbon cable away from the connector with your fingers.
2 farklı kişi bu kılavuzu tamamladı.
