Ana içeriğe geç
HP Envy x360 m6-aq005dx Hard Drive Replacement
Neye ihtiyacın var
  1. HP Envy x360 m6-aq005dx Hard Drive Replacement, Back Panel: adım 1, 2 resimden 1. HP Envy x360 m6-aq005dx Hard Drive Replacement, Back Panel: adım 1, 2 resimden 2.
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Hard Drive Replacement: adım 2, 3 resimden 1. HP Envy x360 m6-aq005dx Hard Drive Replacement: adım 2, 3 resimden 2. HP Envy x360 m6-aq005dx Hard Drive Replacement: adım 2, 3 resimden 3.
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Hard Drive Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. HP Envy x360 m6-aq005dx Hard Drive Replacement, Battery: adım 4, 2 resimden 1. HP Envy x360 m6-aq005dx Hard Drive Replacement, Battery: adım 4, 2 resimden 2.
    • Use a JIS #1 screwdriver to remove the six 4.7 mm screws.
  5. HP Envy x360 m6-aq005dx Hard Drive Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
  6. HP Envy x360 m6-aq005dx Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 1. HP Envy x360 m6-aq005dx Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 2.
    • Use a JIS J1 bit to remove the two 4.6 mm screws.
  7. HP Envy x360 m6-aq005dx Hard Drive Replacement: adım 7, 2 resimden 1. HP Envy x360 m6-aq005dx Hard Drive Replacement: adım 7, 2 resimden 2.
    • The red square is around the ribbon cable.
    • Use the plastic opening tool to open the black security connector. then pull the ribbon cable to disconnect it from the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Matthew Martin
718 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G17, Cagle Fall 2017 USF Tampa, Team S13-G17, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G17
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 13,340
