Giriş
The motherboard is the main circuit board found in a laptop. It manages the communication between crucial electronic components that allow your computer to function. This guide will describe how to remove and replace the motherboard for HP Envy x360m6-aq005dx
Neye ihtiyacın var
Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
Use a JIS #1 screwdriver to remove the 4.7mm screws from the indicated positions.
Use the JIS #1 screwdriver to remove the 7.7mm screws from the indicated positions.
Use the JIS #1 screwdriver to remove the 4.4mm screws from the indicated positions.
Bir başkası bu kılavuzu tamamladı.
