Ana içeriğe geç
HP Envy x360 m6-aq103dx Bottom Cover Replacement
Neye ihtiyacın var
  1. HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: adım 1, 3 resimden 1. HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: adım 1, 3 resimden 2. HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: adım 1, 3 resimden 3.
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Bottom Cover Replacement: adım 2, 1 resimden 1.
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Bottom Cover Replacement: adım 3, 1 resimden 1.
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Bottom Cover Replacement: adım 4, 3 resimden 1. HP Envy x360 m6-aq103dx Bottom Cover Replacement: adım 4, 3 resimden 2. HP Envy x360 m6-aq103dx Bottom Cover Replacement: adım 4, 3 resimden 3.
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Sarah Samora
777 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G3, Livingston Fall 2017 Cal Poly, Team S4-G3, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S4G3
4 Üyeler
9 adet Kılavuz yazıldı
4 Yorum
what should I do if I don’t have a nylon spudger? Is it safe to use my fingers to pry it open? I know I need to be careful about static or else it could fry the comp.
Joshua Bowman - Yanıt
It was really easy to open.
[deleted] - Yanıt
Glad I read this…didn't know about the 2 screws under the grip pads. Once again the internet comes through.
MrHarris73 - Yanıt
But where can i purchase the bottom cover
imran abdulhameed - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 60
Her zaman: 8,663
