Giriş
Is the CPU fan in your HP Envy x360 m6-aq103dx not functioning correctly? Follow this easy replacement guide to open up your computer and replace the CPU fan.
Neye ihtiyacın var
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
Disconnect the port of the fan by flipping the black tab with the small blue plastic opening tool.
Remove the cable from the connector.
4 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Step 5-7 can be bypassed I didn’t need to do it
My first home repair so far. Really easy to follow guide. Great job!
Purchased tools and did the steps, no issues. worth the tools to use later. Worked in iT anyways.
