Ana içeriğe geç
HP Envy x360 m6-aq103dx CPU Fan Replacement
Neye ihtiyacın var
  1. HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: adım 1, 3 resimden 1. HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: adım 1, 3 resimden 2. HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: adım 1, 3 resimden 3.
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 2, 1 resimden 1.
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 3, 1 resimden 1.
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 4, 3 resimden 1. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 4, 3 resimden 2. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 4, 3 resimden 3.
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: adım 5, 3 resimden 1. HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: adım 5, 3 resimden 2. HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: adım 5, 3 resimden 3.
    • Put on the anti-static wristband first
    • Disconnect the port of the fan by flipping the black tab with the small blue plastic opening tool.
    • Remove the cable from the connector.
  6. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 6, 3 resimden 1. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 6, 3 resimden 2. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 6, 3 resimden 3.
    • Peel back a little bit of the grey tape connected to the round cable with the big blue opening tool.
    • Using your fingers, peel the tape off of the body of the computer.
    • Peel slowly to avoid separating the adhesive.
  7. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 7, 2 resimden 1. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 7, 2 resimden 2.
    • Remove the black cable from the fan by unclicking it from the plastic body of the fan with your fingers and move it out of the area.
    • There will be clicking sounds when the black cable is removed.
  8. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 8, 3 resimden 1. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 8, 3 resimden 2. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 8, 3 resimden 3.
    • Disconnect the port with the red yellow and blue wires by dislodging the wires with your fingers.
  9. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 9, 1 resimden 1.
    • Remove the two 4.5mm Phillips #1 screws.
  10. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 10, 1 resimden 1.
    • Loosen the four black screws by the curved heat sink with a Phillips head 1 screwdriver.
    • These screws do not come off.
  11. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 11, 3 resimden 1. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 11, 3 resimden 2. HP Envy x360 m6-aq103dx CPU Fan Replacement: adım 11, 3 resimden 3.
    • Lift the CPU fan out with your hand.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jordan Eremeyeff
597 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G3, Livingston Fall 2017 Cal Poly, Team S4-G3, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S4G3
4 Üyeler
9 adet Kılavuz yazıldı
3 Yorum
Step 5-7 can be bypassed I didn’t need to do it
diego.montenegro23 - Yanıt
My first home repair so far. Really easy to follow guide. Great job!
Caleb Robinson - Yanıt
Purchased tools and did the steps, no issues. worth the tools to use later. Worked in iT anyways.
Roy Rodgers - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 4,481
