Ana içeriğe geç
HP Envy x360 m6-aq103dx RAM Replacement
Neye ihtiyacın var
  1. HP Envy x360 m6-aq103dx RAM Replacement, Bottom Cover: adım 1, 3 resimden 1. HP Envy x360 m6-aq103dx RAM Replacement, Bottom Cover: adım 1, 3 resimden 2. HP Envy x360 m6-aq103dx RAM Replacement, Bottom Cover: adım 1, 3 resimden 3.
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx RAM Replacement: adım 2, 1 resimden 1.
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx RAM Replacement: adım 3, 1 resimden 1.
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx RAM Replacement: adım 4, 3 resimden 1. HP Envy x360 m6-aq103dx RAM Replacement: adım 4, 3 resimden 2. HP Envy x360 m6-aq103dx RAM Replacement: adım 4, 3 resimden 3.
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx RAM Replacement, Battery: adım 5, 2 resimden 1. HP Envy x360 m6-aq103dx RAM Replacement, Battery: adım 5, 2 resimden 2.
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx RAM Replacement: adım 6, 3 resimden 1. HP Envy x360 m6-aq103dx RAM Replacement: adım 6, 3 resimden 2. HP Envy x360 m6-aq103dx RAM Replacement: adım 6, 3 resimden 3.
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx RAM Replacement: adım 7, 3 resimden 1. HP Envy x360 m6-aq103dx RAM Replacement: adım 7, 3 resimden 2. HP Envy x360 m6-aq103dx RAM Replacement: adım 7, 3 resimden 3.
    • Lift the battery out of the laptop with your hands.
  8. HP Envy x360 m6-aq103dx RAM Replacement, RAM: adım 8, 2 resimden 1. HP Envy x360 m6-aq103dx RAM Replacement, RAM: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
  9. HP Envy x360 m6-aq103dx RAM Replacement: adım 9, 3 resimden 1. HP Envy x360 m6-aq103dx RAM Replacement: adım 9, 3 resimden 2. HP Envy x360 m6-aq103dx RAM Replacement: adım 9, 3 resimden 3.
    • Pull the two outer pins on either side of the ram chip outward with your hands.
    • The ram chips should pop up.
    • Do this for both chips.
  10. HP Envy x360 m6-aq103dx RAM Replacement: adım 10, 3 resimden 1. HP Envy x360 m6-aq103dx RAM Replacement: adım 10, 3 resimden 2. HP Envy x360 m6-aq103dx RAM Replacement: adım 10, 3 resimden 3.
    • Remove the chips one at a time, by sliding them towards the side of the computer they are pointing towards.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joey Chen
316 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G3, Livingston Fall 2017 Cal Poly, Team S4-G3, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S4G3
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 4,033
