Ana içeriğe geç
HP Envy x360 m6-aq105dx Audio Jack Replacement
Neye ihtiyacın var
  1. HP Envy x360 m6-aq105dx Audio Jack Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Audio Jack Replacement: adım 2, 1 resimden 1.
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx Audio Jack Replacement, Audio Jack: adım 3, 1 resimden 1.
    • Attach the grounding bracelet's clip to the frame of the laptop, then put on the grounding bracelet.
    • Remove the two 4.6 mm screws using the Phillips #0 screwdriver.
    • Remove the one 4.4mm screw using the Phillips #0 screwdriver.
    • Remove the one 2.8mm screws securing the audio jack/power button board using the Phillips #0 screwdriver.
  4. HP Envy x360 m6-aq105dx Audio Jack Replacement: adım 4, 2 resimden 1. HP Envy x360 m6-aq105dx Audio Jack Replacement: adım 4, 2 resimden 2.
    • Place the blue plastic opening tool on top of the blue data ribbon and under the connector. Lift up on the blue plastic opening tool to open the connector.
    • Remove the blue data ribbon from the audio board.
  5. HP Envy x360 m6-aq105dx Audio Jack Replacement: adım 5, 2 resimden 1. HP Envy x360 m6-aq105dx Audio Jack Replacement: adım 5, 2 resimden 2.
    • Remove the audio jack motherboard from the computer.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 357
