Ana içeriğe geç
HP Envy x360 m6-aq105dx Battery Replacement
Neye ihtiyacın var
  1. HP Envy x360 m6-aq105dx Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Battery Replacement: adım 2, 1 resimden 1.
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Attach the grounding bracelet's clip to the frame of the laptop, then put on the grounding bracelet.
    • Remove the six 4.6mm screws securing the battery using the Phillips #0 screwdriver.
  4. HP Envy x360 m6-aq105dx Battery Replacement: adım 4, 1 resimden 1.
    • Disconnect the power supply cable connected to the motherboard.
  5. HP Envy x360 m6-aq105dx Battery Replacement: adım 5, 2 resimden 1. HP Envy x360 m6-aq105dx Battery Replacement: adım 5, 2 resimden 2.
    • Remove the battery from the device.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 1,355
