Ana içeriğe geç
HP Envy x360 m6-aq105dx Hard Drive Replacement
Neye ihtiyacın var
  1. HP Envy x360 m6-aq105dx Hard Drive Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Hard Drive Replacement: adım 2, 1 resimden 1.
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Attach the grounding bracelet s clip to the frame of the laptop then put on the grounding bracelet.
    • Remove the two 4.6mm screws securing the hard drive in place using the Phillips #0 screwdriver.
  4. HP Envy x360 m6-aq105dx Hard Drive Replacement: adım 4, 1 resimden 1.
    • Disconnect the cable plugged into the hard drive and remove the hard drive from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 619
