Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
The Solid State Drive is responsible for the storing of dynamic random access memory. This guide will instruct on how to replace a Solid State Drive.
  1. Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. Light to moderate force is required to remove the back cover.
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. STUDY UNPLUGGED
    Battery Fix Kits for Mac
    Shop Fix Kits
    STUDY UNPLUGGED
    Shop Fix Kits
  4. Remove the two 4.6 mm screws securing old hard drive/solid-state drive in place using the Phillips #0 screwdriver.
    • Remove the two 4.6 mm screws securing old hard drive/solid-state drive in place using the Phillips #0 screwdriver.
  5. Disconnect the SATA cable connected to the old hard drive/solid-state drive. Remove the solid state drive.
    • Disconnect the SATA cable connected to the old hard drive/solid-state drive.
    • Remove the solid state drive.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 34
