Ana içeriğe geç
HP Envy x360 m6-w101dx Fan Replacement
Neye ihtiyacın var
  1. HP Envy x360 m6-w101dx Fan Replacement, Keyboard Panel: adım 1, 1 resimden 1.
    • Place the laptop so that the bottom panel is facing upwards.
  2. HP Envy x360 m6-w101dx Fan Replacement: adım 2, 3 resimden 1. HP Envy x360 m6-w101dx Fan Replacement: adım 2, 3 resimden 2. HP Envy x360 m6-w101dx Fan Replacement: adım 2, 3 resimden 3.
    • Remove the screw covers using an iFixit opening tool.
  3. HP Envy x360 m6-w101dx Fan Replacement: adım 3, 1 resimden 1.
    • Remove twelve 8 mm Phillips #1 screws.
  4. HP Envy x360 m6-w101dx Fan Replacement: adım 4, 3 resimden 1. HP Envy x360 m6-w101dx Fan Replacement: adım 4, 3 resimden 2. HP Envy x360 m6-w101dx Fan Replacement: adım 4, 3 resimden 3.
    • Pry open a gap in the edge of the keyboard with an iFixit opening tool.
  5. HP Envy x360 m6-w101dx Fan Replacement: adım 5, 1 resimden 1.
    • Remove the keyboard from the laptop.
  6. HP Envy x360 m6-w101dx Fan Replacement, Fan: adım 6, 1 resimden 1.
    • Remove the five 4.5mm Phillips #1 screws surrounding the fan.
  7. HP Envy x360 m6-w101dx Fan Replacement: adım 7, 1 resimden 1.
    • Remove the three 4.5mm Phillips #1 screws from right side of the motherboard.
  8. HP Envy x360 m6-w101dx Fan Replacement: adım 8, 1 resimden 1.
    • Detach the cable between the CPU and the motherboard.
  9. HP Envy x360 m6-w101dx Fan Replacement: adım 9, 1 resimden 1.
    • Detach the cable between the battery and the motherboard.
  10. HP Envy x360 m6-w101dx Fan Replacement: adım 10, 1 resimden 1.
    • Disconnect the cable between the SD card and the motherboard.
  11. HP Envy x360 m6-w101dx Fan Replacement: adım 11, 1 resimden 1.
    • Disconnect the cable between the screen and the motherboard.
  12. HP Envy x360 m6-w101dx Fan Replacement: adım 12, 1 resimden 1.
    • Detach the connection between the fan and the motherboard.
  13. HP Envy x360 m6-w101dx Fan Replacement: adım 13, 1 resimden 1.
    • Disconnect the cable from the speaker to the motherboard.
  14. HP Envy x360 m6-w101dx Fan Replacement: adım 14, 1 resimden 1.
    • Disconnect the cable between the CPU and the power interface.
  15. HP Envy x360 m6-w101dx Fan Replacement: adım 15, 1 resimden 1.
    • Turn the connected motherboard and fan upside down and remove the four 4.5mm Phillips #1 screws from the middle of the back of the motherboard.
  16. HP Envy x360 m6-w101dx Fan Replacement: adım 16, 1 resimden 1.
    • Disconnect the cable connecting the fan to the motherboard.
  17. HP Envy x360 m6-w101dx Fan Replacement: adım 17, 1 resimden 1.
    • Remove the fan from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Wenxuan Zhang
255 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 664
