Giriş
This guide shows how to replace the battery of the HP Envy x360 m6-w103dx. All you need to complete this guide is a plastic opening tool, a #0 Phillips screwdriver.
If you suspect there are issues with the battery, please refer to the troubleshooting guides here.
Working with a full or hot battery could potentially be hazardous. Allow the battery of the laptop to completely run out of battery, and unplug all connections to the laptop before proceeding with the repair. Also, do not attempt to replace the battery immediately after use as it may be hot.
Neye ihtiyacın var
Lift the keyboard until you can see the cables connected to the motherboard.
Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
Detach the keyboard.
8 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Thanks!!!!!!!
