Ana içeriğe geç
HP Envy x360 m6-w103dx Battery Replacement
Neye ihtiyacın var
  1. HP Envy x360 m6-w103dx Battery Replacement, Keyboard: adım 1, 2 resimden 1. HP Envy x360 m6-w103dx Battery Replacement, Keyboard: adım 1, 2 resimden 2.
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Battery Replacement: adım 2, 2 resimden 1. HP Envy x360 m6-w103dx Battery Replacement: adım 2, 2 resimden 2.
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Battery Replacement: adım 3, 3 resimden 1. HP Envy x360 m6-w103dx Battery Replacement: adım 3, 3 resimden 2. HP Envy x360 m6-w103dx Battery Replacement: adım 3, 3 resimden 3.
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Battery Replacement: adım 4, 3 resimden 1. HP Envy x360 m6-w103dx Battery Replacement: adım 4, 3 resimden 2. HP Envy x360 m6-w103dx Battery Replacement: adım 4, 3 resimden 3.
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Battery Replacement, Battery: adım 5, 3 resimden 1. HP Envy x360 m6-w103dx Battery Replacement, Battery: adım 5, 3 resimden 2. HP Envy x360 m6-w103dx Battery Replacement, Battery: adım 5, 3 resimden 3.
    • Remove the four 6 mm Phillips #0 screws holding the battery in place.
    • The white arrows on the battery point to where each screw is.
  6. HP Envy x360 m6-w103dx Battery Replacement: adım 6, 3 resimden 1. HP Envy x360 m6-w103dx Battery Replacement: adım 6, 3 resimden 2. HP Envy x360 m6-w103dx Battery Replacement: adım 6, 3 resimden 3.
    • Unplug the ribbon cable by flipping up the white tabs on the ZIF connectors and gently sliding the ribbon cables out of their sockets.
    • Unplug the battery connector by grasping the small white tabs on either side of the connector and pulling down towards the battery.
  7. HP Envy x360 m6-w103dx Battery Replacement: adım 7, 3 resimden 1. HP Envy x360 m6-w103dx Battery Replacement: adım 7, 3 resimden 2. HP Envy x360 m6-w103dx Battery Replacement: adım 7, 3 resimden 3.
    • Lift out the battery.
    • You may need to peel off the ribbon cable and replace it after installing the new battery if your replacement part doesn't have one already adhered.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Steven Ngo
927 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G2, Regan Fall 2019 Cal Poly, Team S12-G2, Regan Fall 2019 üyesi
CPSU-REGAN-F19S12G2
4 Üyeler
23 adet Kılavuz yazıldı
3 Yorum
Thank you Steven for the provided guide, it helped a lot! There are no guides available on the internet particular for the HP Envy x360 m6-w103dx Battery Replacement. And using the IFIXIT tool kit, it was much easier to replace the battery…love these tools. Awesome job!
Charlie - Yanıt
Thank you, I was able to change the battery successfully, not an easy task with this model of laptop. I would not have been able to do it without your instructions.
Nancy Gaj - Yanıt
Thanks!!!!!!!
John Darling - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 53
Son 30 gün: 208
Her zaman: 7,825
