Giriş
Use this guide to replace your HP Envy x360 m6-w105dx keyboard. You might need to replace your keyboard if the keys are sticky or unresponsive, or you can use this guide for keyboard removal to access the internals for cleaning and repairs. Before beginning, make sure to power off the computer entirely and disconnect from any external power source.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Use the opening pick to lift up the eight rubber grips on the underside of the device.
With the #1 Phillips screwdriver, remove the twelve 6mm screws from the back case.
Bir başkası bu kılavuzu tamamladı.
3 Yorum
This guide is not complete.
This seems to gloss over a lot of important steps and details, “Fully remove the keyboard from the laptop and install your new keyboard.“
Keyboard is attached by plastic tabs, not screws. How do I remove and install the new keyboard?
