Ana içeriğe geç
HP Envy x360 m6-w105dx RAM Replacement
Neye ihtiyacın var
  1. HP Envy x360 m6-w105dx RAM Replacement, Keyboard: adım 1, 3 resimden 1. HP Envy x360 m6-w105dx RAM Replacement, Keyboard: adım 1, 3 resimden 2. HP Envy x360 m6-w105dx RAM Replacement, Keyboard: adım 1, 3 resimden 3.
    • Make sure the laptop is powered off and disconnected from any outlets.
    • Use the opening pick to lift up the eight rubber grips on the underside of the device.
    • With the #1 Phillips screwdriver, remove the twelve 6mm screws from the back case.
  2. HP Envy x360 m6-w105dx RAM Replacement: adım 2, 2 resimden 1. HP Envy x360 m6-w105dx RAM Replacement: adım 2, 2 resimden 2.
    • Open the laptop and turn to the keyboard.
    • Gently insert an opening pick into the edge of the keyboard panel, and slide around the keyboard lining until the clips have all been disengaged.
    • Lift the keyboard panel from the bottom and carefully start to lift up.
    • There are ribbon cables still connected on the under side of the the keyboard. Do not pull the keyboard away from the device.
  3. HP Envy x360 m6-w105dx RAM Replacement: adım 3, 2 resimden 1. HP Envy x360 m6-w105dx RAM Replacement: adım 3, 2 resimden 2.
    • Gently lift the keyboard up from the bottom.
    • Carefully open the locking flap of the three ZIF connectors and detach the three ribbon cables from the motherboard using your fingers.
    • Do not remove the ZIF connectors by pulling on the wires, instead detach them by gently flipping up the plastic tabs located at the ends of the wiring.
    • Fully remove the keyboard from the laptop and install your new keyboard.
  4. HP Envy x360 m6-w105dx RAM Replacement, RAM: adım 4, 3 resimden 1. HP Envy x360 m6-w105dx RAM Replacement, RAM: adım 4, 3 resimden 2. HP Envy x360 m6-w105dx RAM Replacement, RAM: adım 4, 3 resimden 3.
    • Gently open the ZIF connectors and remove the ribbon cables.
    • Unscrew the five 4mm screws with the Phillips #1 screwdriver.
    • Unscrew the WLAN chip and push the chip up and out of the port.
    Make sure to capitalize Phillips. For all ZIF connectors, indicate how to remove, just not to remove them. Each of these steps should have pictures depicting you doing these things, not just to do them with markup.
    Alex Watkins - Yanıt
  5. HP Envy x360 m6-w105dx RAM Replacement: adım 5, 2 resimden 1. HP Envy x360 m6-w105dx RAM Replacement: adım 5, 2 resimden 2.
    • Disconnect the cable connectors for the speakers.
    • Lift the motherboard up and flip towards you to disconnect an additional cable connector on the rear side.
    • Use an opening pick to pull the motherboard up on the fan side. Then pull the motherboard assembly out towards the left.
    How should I disconnect the connectors? What do these connectors do? How should I lift and flip the motherboard? How should I remove the pieces? I also need more pictures.
  6. HP Envy x360 m6-w105dx RAM Replacement: adım 6, 3 resimden 1. HP Envy x360 m6-w105dx RAM Replacement: adım 6, 3 resimden 2. HP Envy x360 m6-w105dx RAM Replacement: adım 6, 3 resimden 3.
    • On the underside of the motherboard, use the halberd spudger to pry up the square metal cover.
    • The metal cover is used to protect the RAM chips.
    I think you could just markup the first shot, then get a shot of you lifting the covering with the spudger. Also, be sure to indicate how to use the spudger, not just to do it.
  7. HP Envy x360 m6-w105dx RAM Replacement: adım 7, 3 resimden 1. HP Envy x360 m6-w105dx RAM Replacement: adım 7, 3 resimden 2. HP Envy x360 m6-w105dx RAM Replacement: adım 7, 3 resimden 3.
    • Pull the metal retaining pins on either side of the RAM stick apart. The RAM stick will pop up.
    • Remove the RAM and insert a new one that is compatible.
    • Do not force the RAM stick or it will snap.
    • When doing a RAM replacement, make sure the correct chip is being used.
    Which metal pins? Do you need a tool, or use your hands? Do you have a picture of it popped up, before you grab it out? I think you could replace the first picture with one in the middle with the component popped out.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
this is the first time i’ve been on the ifixit site but thanks to my google search of this topic, I found this and it is extremely simple and helpful. I haven’t actually done this yet but am confident I can once I get the replacement ram. I need my laptop to be a portable video editing work station and the stock ram on these will run premiere pro, just very very slowly.
Tyler - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 973
