Ana içeriğe geç
HP Flyer Red Battery Replacement
  1. HP Flyer Red Battery Replacement, Battery: adım 1, 2 resimden 1. HP Flyer Red Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. HP Flyer Red Battery Replacement: adım 2, 1 resimden 1.
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
    FixBot'a Sor
    Yorum Ekle
  3. HP Flyer Red Battery Replacement: adım 3, 2 resimden 1. HP Flyer Red Battery Replacement: adım 3, 2 resimden 2.
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
    FixBot'a Sor
    Yorum Ekle
  4. HP Flyer Red Battery Replacement: adım 4, 1 resimden 1.
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Anthony Ciotti
777 İtibar
5 adet Kılavuz yazıldı
1Rehber Yorum
What do you do when the battery not charging but the laptop is working when directly plugged on power
liberty siegmann derera - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 2,750
