Giriş
Make sure you have completed the keyboard replacement guide and the top cover removal guide.
A dead battery can prevent your laptop from turning on. This guide will show you how to correctly replace the battery and restore power for your HP Folio 13t-1000.
Neye ihtiyacın var
Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
Do the same for the second connection.
