Ana içeriğe geç
HP G60 RAM Replacement
Neye ihtiyacın var
  1. HP G60 RAM Replacement, Battery: adım 1, 3 resimden 1. HP G60 RAM Replacement, Battery: adım 1, 3 resimden 2. HP G60 RAM Replacement, Battery: adım 1, 3 resimden 3.
    • First, you should to remove the battery to avoid electric shocks
    • Slide and unlock the battery, then, lift it
    FixBot'a Sor
    Yorum Ekle
  2. HP G60 RAM Replacement, RAM cover: adım 2, 3 resimden 1. HP G60 RAM Replacement, RAM cover: adım 2, 3 resimden 2. HP G60 RAM Replacement, RAM cover: adım 2, 3 resimden 3.
    • Remove the two screws with a not too large screwdriver
    • Now lift the cover, the screws are part of the cover
    FixBot'a Sor
    Yorum Ekle
  3. HP G60 RAM Replacement, Eject RAM: adım 3, 3 resimden 1. HP G60 RAM Replacement, Eject RAM: adım 3, 3 resimden 2. HP G60 RAM Replacement, Eject RAM: adım 3, 3 resimden 3.
    • Push the little aluminum locks at the top and the bottom of the ram
    • The memory will lift, then pull it
    • Make this with the another RAM slot
    FixBot'a Sor
    Yorum Ekle
  4. HP G60 RAM Replacement, New RAM: adım 4, 3 resimden 1. HP G60 RAM Replacement, New RAM: adım 4, 3 resimden 2. HP G60 RAM Replacement, New RAM: adım 4, 3 resimden 3.
    • The new RAM memory should to be insert in a 45 degrees angle
    • Then, push it and the memory will lock by itself
    • Make this with the second memory
    FixBot'a Sor
    Yorum Ekle
  5. HP G60 RAM Replacement, RAM cover (Again): adım 5, 3 resimden 1. HP G60 RAM Replacement, RAM cover (Again): adım 5, 3 resimden 2. HP G60 RAM Replacement, RAM cover (Again): adım 5, 3 resimden 3.
    • Insert the cover from right to left, then, screw it
    • If cover is lifted, press it softly and secure it
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
jimenezser
3.905 İtibar
4 adet Kılavuz yazıldı
1Rehber Yorum
Thanks for verifying the RAM replacement and that it was as easy as I thought it was, but that made me a bit nervous, being much more comfortable building desktops as large as my or my customer's budget would allow!
Take 'em out, put new ones back in. As a technical writer, I also appreciate that you kept it to the point without creating further questions to complicate that which is not complicated. Thanks again. Will check out some out your other work.
J Brent Masters - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 54
Her zaman: 6,832
