Ana içeriğe geç
HP G60T-600 CTO Hard drive Replacement
Neye ihtiyacın var
  1. HP G60T-600 CTO Hard drive Replacement, Battery: adım 1, 1 resimden 1.
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO Hard drive Replacement: adım 2, 2 resimden 1. HP G60T-600 CTO Hard drive Replacement: adım 2, 2 resimden 2.
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO Hard drive Replacement: adım 3, 1 resimden 1.
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO Hard drive Replacement, Hard drive: adım 4, 2 resimden 1. HP G60T-600 CTO Hard drive Replacement, Hard drive: adım 4, 2 resimden 2.
    • Remove the 5cm screws with a #00 Phillips screwdriver.
    • Take the cover off.
  5. HP G60T-600 CTO Hard drive Replacement: adım 5, 3 resimden 1. HP G60T-600 CTO Hard drive Replacement: adım 5, 3 resimden 2. HP G60T-600 CTO Hard drive Replacement: adım 5, 3 resimden 3.
    • Remove the following .5cm screws with a #0 Phillips screwdriver.
    • Slide the hard drive cover to the right with light-medium force.
  6. HP G60T-600 CTO Hard drive Replacement: adım 6, 1 resimden 1.
    • Pull up on the little black tab on the hard drive case to remove it.
    • From here you will be able to carefully slide your hard drive out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dominic DeSantis
748 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Catania Fall 2016 UMass Dartmouth, Team 4-5, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 160
