Ana içeriğe geç
HP G60T-600 CTO Keyboard Replacement
Neye ihtiyacın var
    1. HP G60T-600 CTO Keyboard Replacement, Battery: adım 1, 1 resimden 1.
      • Failure to remove the battery before performing any replacement guide may result in electric shock.
      • Close your device, then turn it over.
      FixBot'a Sor
      Yorum Ekle
    2. HP G60T-600 CTO Keyboard Replacement: adım 2, 2 resimden 1. HP G60T-600 CTO Keyboard Replacement: adım 2, 2 resimden 2.
      • Place your index finger on the ridged tab.
      FixBot'a Sor
      Yorum Ekle
    3. HP G60T-600 CTO Keyboard Replacement: adım 3, 1 resimden 1.
      • Apply moderate pressure to the tab and slide it to the right.
      • While the tab is on the right, you should be able to gently slide your battery out of your device.
      FixBot'a Sor
      Yorum Ekle
    1. HP G60T-600 CTO Keyboard Replacement, Keyboard: adım 4, 2 resimden 1. HP G60T-600 CTO Keyboard Replacement, Keyboard: adım 4, 2 resimden 2.
      • Unscrew the following 5mm screws with a #0 Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. HP G60T-600 CTO Keyboard Replacement: adım 5, 1 resimden 1.
      • Turn your laptop over and open it up.
      • Grip your laptop firmly from both sides and use your thumbs to slide the keyboard towards the screen.
      FixBot'a Sor
      Yorum Ekle
    3. HP G60T-600 CTO Keyboard Replacement: adım 6, 1 resimden 1.
      • Pull up on the top of your keyboard with medium force. It should start to pop out.
      • A plastic opening tool may facilitate this task.
      • Run your hands underneath the edges of the keyboard until it is free from the device.
      • Do not pull hard to take the keyboard out. There is a small connection that needs to be undone.
      FixBot'a Sor
      Yorum Ekle
    4. HP G60T-600 CTO Keyboard Replacement: adım 7, 2 resimden 1. HP G60T-600 CTO Keyboard Replacement: adım 7, 2 resimden 2.
      • Place your thumbs on the two small, white tabs.
      • Push these tabs forward to release the connection and free the keyboard from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dominic DeSantis
772 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Catania Fall 2016 UMass Dartmouth, Team 4-5, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G5
3 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 398
