Ana içeriğe geç
HP G60T-600 CTO RAM Replacement
Neye ihtiyacın var
  1. HP G60T-600 CTO RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
    FixBot'a Sor
    Yorum Ekle
  2. HP G60T-600 CTO RAM Replacement: adım 2, 2 resimden 1. HP G60T-600 CTO RAM Replacement: adım 2, 2 resimden 2.
    • Place your index finger on the ridged tab.
    FixBot'a Sor
    Yorum Ekle
  3. HP G60T-600 CTO RAM Replacement: adım 3, 1 resimden 1.
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
    FixBot'a Sor
    Yorum Ekle
  4. HP G60T-600 CTO RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Turn your device over and orient it so the battery is facing you.
    FixBot'a Sor
    Yorum Ekle
  5. HP G60T-600 CTO RAM Replacement: adım 5, 3 resimden 1. HP G60T-600 CTO RAM Replacement: adım 5, 3 resimden 2. HP G60T-600 CTO RAM Replacement: adım 5, 3 resimden 3.
    • Unscrew the following 5mm screws using a Phillips head #0 screwdriver.
    • Remove the cover.
    FixBot'a Sor
    Yorum Ekle
  6. HP G60T-600 CTO RAM Replacement: adım 6, 3 resimden 1. HP G60T-600 CTO RAM Replacement: adım 6, 3 resimden 2. HP G60T-600 CTO RAM Replacement: adım 6, 3 resimden 3.
    • Place your fingers on little metals tabs on both sides of the RAM casing.
    • Push the tabs towards the sides. This should cause the RAM to pop up.
    FixBot'a Sor
    Yorum Ekle
  7. HP G60T-600 CTO RAM Replacement: adım 7, 1 resimden 1.
    • Pull on it with medium force at the angle it is oriented.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dominic DeSantis
772 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Catania Fall 2016 UMass Dartmouth, Team 4-5, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G5
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 346
