Ana içeriğe geç
HP G62 347NR CD/DVD Drive Replacement
Neye ihtiyacın var
  1. HP G62 347NR  CD/DVD Drive Replacement, CD/DVD Drive: adım 1, 1 resimden 1.
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR  CD/DVD Drive Replacement: adım 2, 1 resimden 1.
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR  CD/DVD Drive Replacement: adım 3, 1 resimden 1.
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR  CD/DVD Drive Replacement: adım 4, 1 resimden 1.
    • On the far left of the hard drive compartment, find the Phillips head screw.
    • Remove the Phillips head screw with the PH1 screwdriver.
  5. HP G62 347NR  CD/DVD Drive Replacement: adım 5, 2 resimden 1. HP G62 347NR  CD/DVD Drive Replacement: adım 5, 2 resimden 2.
    • Get the plastic opening tool and place it between the laptop and the CD/DVD drive. Place it toward the center of the drive for maximum support.
    • Carefully pry the CD/DVD drive open.
    • Slide the CD/DVD drive out once it is pried open.
Sonuç
McKenzi Morris
511 İtibar
3 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 6-1, Bennett Fall 2016 Texas Tech, Team 6-1, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S6G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 545
