Ana içeriğe geç
HP G62-144DX Hard Drive Replacement
Neye ihtiyacın var
  1. HP G62-144DX Hard Drive Replacement, Battery: adım 1, 2 resimden 1. HP G62-144DX Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 1. HP G62-144DX Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 2. HP G62-144DX Hard Drive Replacement, Hard Drive: adım 2, 3 resimden 3.
    • Loosen the 2 Phillips 2.5x6 screws in the rectangular panel with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but come free from the body of the computer.
    • Gently remove the panel with a plastic opening tool.
  3. HP G62-144DX Hard Drive Replacement: adım 3, 3 resimden 1. HP G62-144DX Hard Drive Replacement: adım 3, 3 resimden 2. HP G62-144DX Hard Drive Replacement: adım 3, 3 resimden 3.
    • Unscrew the three 3x4 Phillips screws holding the hard drive in with a Phillips #1 screwdriver.
    • Pull the hard drive cable out of the motherboard.
    • Pull the hard drive out of the computer.
Sonuç
Cameron Moran
623 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G8, Julie Fall 2017 UMass Dartmouth, Team S4-G8, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S4G8
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 315
