Ana içeriğe geç
HP G62-144DX Keyboard Replacement
Neye ihtiyacın var
  1. HP G62-144DX Keyboard Replacement, Battery: adım 1, 2 resimden 1. HP G62-144DX Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Keyboard Replacement, Keyboard: adım 2, 1 resimden 1.
    • Remove the 3 Phillips 2.5x5 screws (closest to the battery slot) and the 2 Phillips 2.5x6.5 screws with a Phillips #1 screwdriver.
    • This screws will have a keyboard symbol inscribed next to them.
  3. HP G62-144DX Keyboard Replacement: adım 3, 3 resimden 1. HP G62-144DX Keyboard Replacement: adım 3, 3 resimden 2. HP G62-144DX Keyboard Replacement: adım 3, 3 resimden 3.
    • Use the Phillips # 1 screwdriver to unscrew the 2.5x6 Phillips screws holding the L-shaped back panel.
    • Screws should stay in panel, but come free of the laptop body.
    • Gently use a plastic opening tool to remove the panel.
  4. HP G62-144DX Keyboard Replacement: adım 4, 2 resimden 1. HP G62-144DX Keyboard Replacement: adım 4, 2 resimden 2.
    • Unscrew the final Phillips 2.5x5 keyboard screw with a Phillips #1 screwdriver.
  5. HP G62-144DX Keyboard Replacement: adım 5, 2 resimden 1. HP G62-144DX Keyboard Replacement: adım 5, 2 resimden 2.
    • Flip the laptop so the top is facing up again and open the cover.
    • Use a metal spudger to pry the keyboard up and pull it back.
    • Be sure to pry up the board itself and not an individual key.
    • This process has the risk of breaking keys.
  6. HP G62-144DX Keyboard Replacement: adım 6, 2 resimden 1. HP G62-144DX Keyboard Replacement: adım 6, 2 resimden 2.
    • Pull up the latch that connects the keyboard connector the the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Cameron Moran
623 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G8, Julie Fall 2017 UMass Dartmouth, Team S4-G8, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S4G8
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 588
