Ana içeriğe geç
HP G62-144DX RAM Replacement
Neye ihtiyacın var
  1. HP G62-144DX RAM Replacement, Battery: adım 1, 2 resimden 1. HP G62-144DX RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX RAM Replacement, RAM: adım 2, 3 resimden 1. HP G62-144DX RAM Replacement, RAM: adım 2, 3 resimden 2. HP G62-144DX RAM Replacement, RAM: adım 2, 3 resimden 3.
    • Unscrew the three Phillips 2.5x6 screws in the L-shaped panel on the back with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but will come loose from the body of the laptop.
    • Use a plastic opening tool to gently pry the panel free from the laptop.
  3. HP G62-144DX RAM Replacement: adım 3, 3 resimden 1. HP G62-144DX RAM Replacement: adım 3, 3 resimden 2. HP G62-144DX RAM Replacement: adım 3, 3 resimden 3.
    • Pull the two metal clips to the top RAM module outwards parallel to the laptop.
    • After the RAM module pops up, gently pull in out from the computer.
    • Repeat for the second RAM module.
Sonuç
Cameron Moran
623 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G8, Julie Fall 2017 UMass Dartmouth, Team S4-G8, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S4G8
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 321
