Ana içeriğe geç
HP G62-223CL Hard Drive Replacement
Neye ihtiyacın var
    1. HP G62-223CL Hard Drive Replacement, Battery Removal: adım 1, 2 resimden 1. HP G62-223CL Hard Drive Replacement, Battery Removal: adım 1, 2 resimden 2.
      • Removing the battery while the laptop is still on may corrupt your files.
      • Turn the device over to expose the bottom of the device.
      • Slide the battery release all the way to the left.
      • There will be a click and the battery will be released from its compartment.
      FixBot'a Sor
      Yorum Ekle
    2. HP G62-223CL Hard Drive Replacement: adım 2, 1 resimden 1.
      • Carefully remove the battery from its compartment.
      FixBot'a Sor
      Yorum Ekle
    1. HP G62-223CL Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. HP G62-223CL Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
      • Locate the two Phillips head retaining screws which secure the hard drive compartment.
      • Use a Phillips #0 screwdriver to loosen the retaining screws.
      • Remove the panel covering the compartment.
      • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
      FixBot'a Sor
      Yorum Ekle
    2. HP G62-223CL Hard Drive Replacement: adım 4, 1 resimden 1.
      • Locate the three 6 mm Phillips head screws for the hard drive.
      • Use a Phillips #0 screwdriver to remove the screws.
      FixBot'a Sor
      Yorum Ekle
    3. HP G62-223CL Hard Drive Replacement: adım 5, 1 resimden 1.
      • Remove the hard drive from the compartment.
      • Pull the connector cable from the end of the hard drive.
      FixBot'a Sor
      Yorum Ekle
    4. HP G62-223CL Hard Drive Replacement: adım 6, 1 resimden 1.
      • Locate the two 6 mm Phillips head screws on each side of the hard drive.
      • Remove the cover from the hard drive.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Garret Layton
687 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Sullivan Winter 2015 USF Tampa, Team 1-4, Sullivan Winter 2015 üyesi
USFT-SULLIVAN-W15S1G4
4 Üyeler
30 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 41
Her zaman: 3,102
