Ana içeriğe geç
HP G62-223CL Optical Drive Replacement
Neye ihtiyacın var
  1. HP G62-223CL Optical Drive Replacement, Battery Removal: adım 1, 2 resimden 1. HP G62-223CL Optical Drive Replacement, Battery Removal: adım 1, 2 resimden 2.
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Optical Drive Replacement: adım 2, 1 resimden 1.
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Optical Drive Replacement, Optical Drive: adım 3, 1 resimden 1.
    • Locate two Phillips head retaining screws which secure the hard drive compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Optical Drive Replacement: adım 4, 1 resimden 1.
    • Locate the 6 mm Phillips head screw to the left of the hard drive.
    • Use a Phillips #0 screwdriver to remove the screw.
  5. HP G62-223CL Optical Drive Replacement: adım 5, 2 resimden 1. HP G62-223CL Optical Drive Replacement: adım 5, 2 resimden 2.
    • Once the screw is removed, use a plastic opening tool and place it between the body of the computer and the optical drive.
    • Apply enough pressure to loosen the optical drive.
    • The optical drive can then be removed by hand.
Sonuç
Garret Layton
669 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Sullivan Winter 2015 USF Tampa, Team 1-4, Sullivan Winter 2015 üyesi
USFT-SULLIVAN-W15S1G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 1,239
